Anonymous
Mar 07, 2016Not applicable
As said above, the instructions say start at the 9th link from the loose end. There should be 16 links all together so you'd would start at the 7th link from the U bolt. You can flip the shank. If you can't get enough height out of the standard shank then let Blue Ox know and they'll swap it out for you. The ball should be between equal to 1 inch higher than the height of the leveled coupler.
As to how many links you can safely use, I asked Blue Ox this question. According to Blue Ox you can use as many links as you needed to level the truck. There's no minimum amount of links that need to be maintained below the latches. They've had people report to them that they've used every link available. Using more links should not hurt the bars.
44,068 PostsLatest Activity: Jun 21, 2026
