Walaby wrote:
I just looked at the Equalizer hitch. I like that design. It's similar to my Husky Centerline TS. I may look into that instead. Question for you... Do you have to remove the bars to backup or can they remain hooked up?
Anything you don't like about the Equalizer?
Mike
You do not have to remove bars to back up. This our second Equalizer setup and both have worked fantastic. There is some squeaking when turning from the bars sliding on the TT frame brackets, but that tells you the system is working. Do not grease the bars to eliminate the noise.
