Redterpos3
Nov 14, 2013Explorer
Blue Tote?
I've heard about using the blue tote for dumping so you don't have to move the rig. When the tote is not as large as the tanks you are dumping from do you just have to wing it and hope you shut it do...
The Thetford video says it has some kind of autostop that "stops flow when tank is full to prevent messy over-filling", how does it do that, and what happens to the "stuff" between the tote and the dump valve, or does it stop just short of full, and allow you to shut the valve?I have this tank, an it does have a little red indicator that pops up when full. You can tell when it is getting full and I usually stop before so I can empty the contents of the filler hose. And I haul black and gray water. This tank also has a hose hookup to clean the inside, and it tows real nice.
