boogie_4wheel wrote:
Lost ground clearance will depend on vehicle and hitch manufacturer.
The Bodiak is a nice idea, but I wouldn't buy one. Have a hitch mounted winch? Then you can't use your tow hooks to attach to when using a snatch block.
Own a 3rd Gen Dodge? The tow hooks are not direct-frame mount. They are mounted to a bracket (also holding the front bumper in place) that is bolted to the frame. Shock load the hitch and you could misalign the front bumper/tow hooks/hitch, and have the possibility of the bumper contacting the front fenders.
Direct bolt on for me. I was going to fab up a hitch similar to the Bodiak (in terms of location, but mount behind the hooks then decided against it because of the not-direct-frame) but I ended up with a Curt (purchased used locally). It hung down below the plastic air dam. I cut it up and welded it so that it protrudes just below the front license plate mount and gaining me 2.5" of ground clearance.
I owned a 2006 3rd generation Dodge 2500 diesel 4x4 and mounted the Bodiak right on the tow hooks and had no problems with loading up cargo hitch
at all. No cutting of the fascia either.. Two thumbs up for Bodiak here!!
