richclover wrote:
ktmrfs wrote:
There is IMHO to little tire clearance. Either it was built with to little clearance, or the tires are larger than the OEM tires, or the springs have lost the arc.
If it was my trailer and fixing it correctly isn't covered under warranty, I'd find a shop that can do an axle flip to get proper clearance.
I don't think an axle flip will will help. As shown, the axles are mounted below the springs.
correct. I suffered from a bit of "brain fade" when I looked at the picture.
The larger tires of 1" larger diameter only cut about 1/2" of clearance. From the looks it is several inches from the needed clearance.
