Old-Biscuit
Oct 21, 2013Explorer III
Older model converters need battery to act as a load......
Check for blown dc fuses, burnt out bulbs, bad grounding on those lights that don't work.
You can also check converter output....voltmeter should read 13.6V DC output (test where battery cables would connect to converter). Lower reading...converter not doing it's job.
You can contact KZ...might have some info about your rig...LINK
44,060 PostsLatest Activity: May 06, 2023
