houtrz's avatar
houtrz
Brake Booster
We are getting ready to pick up our new travel trailer in a few weeks and I need to get a brake booster set up on a 2012 Mercedes Benz ML350 diesel. I have called several places and they will not install a brake booster with out the factory wiring harness. I called Mercedes and the parts guy told me they don't sell that then went on to say the brakes would work buy simply using the seven pin connection on the vehicle. Does Mercedes ML come with a build in brake booster? This vehicle is rated to tow 7300 pounds so I'm sure I'm not the first person to ever encounter this. Suggestions?
  • google found
    http://www.benzworld.org/forums/w166-m-class-gle-class/1632988-trailer-brake-controllers.html
    http://www.benzworld.org/forums/w166-m-class-gle-class/1954002-2012-ml350-trailer-hitch-wiring.html
  • Thanks for the replies and correction on my terms. I'll dig a little deeper.
  • Google: 2012 Mercedes Benz ML350 brake controller
    Plenty of information there.
  • X2 what Fred said.
    You need a good "brake controller" preferably one like Prodigy 2 or Prodigy 3 (Teknosha brand) If I were you, I'd be speaking to a different Mercedes dealership!
  • I think that you are talking about a electric brake controller.
    Brake boosters are used for power brakes on the car, or whatever vehicle you are talking about. It is the wrong term, therefore the confusion about what to install or where to install it.
    Aftermarket electric brake controllers do not require the factory harness tie in. Basically they take 12 volt power from the brake pedal switch (or tap into the line going to the third brake light) and also have a 30 amp rated connection to the battery or fuse box with #10 wire and a 30 amp fuse (20 amps for some trailers). I would recommend a 30 amp automatic reset circuit breaker, so it will not trip and leave you without trailer brakes, but would reset itself after about 5 minutes.
    The wiring can be buried under the carpet, just like a stereo installation, and run to the 7 wire harness that the trailer plugs into. If you did not get the 'factory' wiring package, you might be better off, because you could install #10 wire to a 30 auto reset CB on a wire from the battery to a relay that will only come on with the engine (fog light 30 amp relay will work great) to #10 wire all the way to the battery + of the 7 pin connector. Most cars and trucks that have 'Trailer Prep' only include a #12 wire, and it will not move as much power to the battery as a #10 wire will.
    Good luck,
    Fred.
