vicmitch's avatar
vicmitch
Brake light comes on on tow vehicle towing camper ???
After about 30 to 50 miles down the road towing camper, brake light comes on on our 2012 Dodge Durango . I suspect it is because the trailer brakes aren't being engaged well nuf by the brake controller. Is it possible for the Durango brake computer to pick up the extra load on the brakes and turn on the light ? If I play with the brake pedal and get the trailer brakes to engage, the light seems to stay off.
I definitely want to try another tow vehicle brake controller, what is the best performing brake controller now on the market? I hear about something called the Prodigy.
  • The brake light wont come on because the turck doesn't think the trailer brakes are good enough.
    Brake light comes on if there's an issue with low pressure in the system, if there's a computer or a few other obscure reasons.
    I would check the brake fluid level first. After that I would make sure nothing is leaking, especially at the wheels.
  • try replacing the brake light switch in the truck.. it's like 12 dollars and 2 minutes to replace.
    Yes, Prodigy makes several units.. I like the P3.
