dodge_guy
Oct 12, 2014Explorer II
Turtle n Peeps wrote:
It makes no sense that you lost all braking capability. :h
As pointed out above, all brake systems that have been made since around the 70's have a split system. How modern brakes work.
Duel reservoir in the master cylinder, duel or shuttle piston, duel lines front and rear. Everything is redundant. It's built that way just for the reason you encountered.
You should have had some brakes, either complete front or complete rear.
In theory that is how it is supposed to work. But unfortunately in the real world it doesn't! I can tell you from being a mechanic and fixing rusted/broken brake lines that when only one circuit of the system leaks the pedal will go to the floor.
44,068 PostsLatest Activity: Jun 01, 2026
