wgriswold's avatar
wgriswold
Brake rewiring
While taking my trailer to storage I got three messages:
"Check trailer wiring"
"Check trailer brake wiring"
"Trailer brakes disconnected"
The brakes were periodically disconnected which I confirmed with the manual brake function.
I have replaced the 7 pin cord and the next step is to replace the trailer brake wiring. I can do this job and my experience with boating electrical systems causes me to much prefer crimped connections. I am planning on running 12 gauge double wires down each side.
My problem is that I can't figure out how to connect two wires into one with a crimp. I need to do that at both ends of the new wire. There are Y connectors that would work but I would prefer a connection that would be entirely under heat shrink tubing. Is there a better solution?
As always, thanks for your help.
  • hohenwald48 wrote:
    trail-explorer wrote:
    Soldering is a bad idea in an application (such as RVs) where things move.
    Electrical background from the USAF, the one thing that was drilled in to our heads was "soldering isn't a preferred practice on wires in a vehicular application".
    Ditto the "no solder" information. Especially in a corrosive environment like under a trailer and inside an axle tube.
    I've been soldering and taping for way too many years and have never had a connection failure. Now I find I am doing it wrong. Never too late to learn. I am curious though as to the rational for no solder.
  • Have you checked your ground?? Bad grounds affect more things than one can imagin.
  • Soldering is a bad idea in an application (such as RVs) where things move.
    Heat shrink crimp connectors are fine.
    With regard to your trailer pigtail, does it have movement (side to side) in the truck's plug?
    It's a known fact that there are some trailer pigtail manufacturers that don't build their plugs to the exact spec (in diameter) and they fit loosely in the OEM truck receptacle.
    If the plug has any slop in the truck's receptacle, that's the most likely source of the problem
  • One word "SOLDER". I have built custom motorcycles for the 10 years and found through this experience the importance of soldering all wiring connections whether the crimp variety or not. I remove the hard plastic insulation from the connector and crimp in postion, then solder. I then follow up with heat shrink tubing for insulation.
  • enblethen wrote:
    A #10 butt connector should be able to handle two #12 SAE multi-strand wires.
    I would suggest injecting electrical grease into the connectors prior to crimping.
    X2 ^ ^
    But one question have you determined where your problem is.
    If you look up my older post I had the same issue and it turned out to be the magnets and the additional wiring all cooked and died.
  • A #10 butt connector should be able to handle two #12 SAE multi-strand wires.
