travisgsf
Jan 04, 2015Explorer
Brake Upgrade 2012 F250
I want to upgrade my brakes for better stopping power and better feel. Any thoughts as to what's the best route?  I'm willing to change whatever I need to not just the pads. Thanks
Golden_HVAC wrote:
Hi,
I would start by changing out the brake fluid, and get the Ford 24,000 GVWR motorhome brake fluid, it has the very highest 'wet' boiling point of any brake fluid.
Bedlam wrote:
FYI: The F350 DRW and chassis cab DRW use larger brakes, but none use tires taller than 33".
travisgsf wrote:
I am running slightly larger tires on the 5th wheel. BFG Commercial TA. Also running an inch larger on my truck. 35" tires. Only reason I assumed upgrade the trucks brakes is when not towing my truck brakes feel really mushy. I only have 30k miles on the truck
Turtle n Peeps wrote:
My first question is why?
IOW's here's the problem. The tires are the weakest link. Even with ABS the tires are the weakest link if you want to stop quicker.
Now duty cycle is a different subject. If you can put 10' brakes on your truck you can ride them for days and never get them hot. But again, why would you want that?
So, why do you want different brakes than OEM?
