an updte, I'm chasing down voltage drops through the system, after all 7 inch brakes are going to take a lot more electrical power for the same braking action
with the brake controller fully applied I had 8 volts at the "last" brake, 12.6 volts at the truck battery
so I started at the rear of the trailer and replaced the brake feeds with twin two wire cables 14 ga, one down each side of the trailer, then added a new 14 ga from the battery via the breakaway and a new ground. the new wiring goes into the junction box under the trailer where all brake connections have soldered ring terminals and are bolted together, the ground right to the box, the hot leads on an insulated stud mounted on the box.
the brake and ground leads from the 7 pin were also wired to those studs
I also replaced the wiring for the brake controller from the truck battery, brake controller all the way to the 7 pin. went from 16 ga to 10 ga with a ground wire all the way back. I used a 10-3 cable, the third conductor is used for the 12 volt feed to the trailer and also feeds an outlet in the truck bed where we have a 12v fridge
it surprises me how much voltage drop there was in 30 feet of 16ga, 2-2.5 volts at 16 amps plus all the mickey mouse connectors, corroded ends etc etc. its easy to measure voltage drop over a section, a vom with a sharp probe and a ground connection soon shows the "bad" spots
braking action is better, but not like our previous trailer with 10 inch brakes
