Grit dog wrote:
And if a person, especially living in the salt belt, does not adequate lube the slides, that is the second most likely cause IMO.
No "light grease rubs" into the pores of the steel. First, it sounds dirty or you're having too much fun rubbing your pins...
Anti seize that stuff and be done with it.
Glad you enjoyed my "grease rub" comment. What I meant to say
was I used the smallest amount of "grease" to moisten the metal without the danger of getting it on the pads or rotor. To do that I have used my bottle of brake caliper lube, or those little packets that they sometimes throw in, or anti-seize - I've tried them all.
I've considered the salt issue. I clean my brakes every year, only because of this problem, and I see no salt-related issues. I've heard some people talk about concern over the "beet juice" that they spread on the roads here - some say it is more corrosive then salt but, again, I'm not seeing it in my brakes and my truck is still almost rust-free. And my other vehicles are having no problems like this.
I too have been exercising the ABS system as well as I can to purge out old fluid but I've also heard that having a computer program that can open the valves in the ABS would be a nice way to flush it out completely, But since I have been having this problem since the truck was nearly new I wonder if the ABS unit has been defective rather then worn out or old but haven't found anything on the internet that would support that thought.
If you are wondering why I didn't take the truck in under warranty for the ABS unit - this problem wasn't that obvious until after the warranty expired. I hadn't put many miles on it and I thought the problems were related to lack of use.
