Big_Katuna
Sep 15, 2013Explorer II
You need to measure the actual voltage at the brakes with a voltmeter to make sure your wiring has integrity. You can take a 15A battery charger and activate/test your brakes with that. You should do it through the seven wire connector with a test plug to the charger. A lot of brake problems are wiring related.,
44,056 PostsLatest Activity: Jan 12, 2020
