- IdahoRVingExplorer:C
- aftermathExplorer IIIAt times like these it is hard not to go ballistic. I would request a new trailer or full money back. I would also try to find a lawyer friend to write a letter. This is totally unacceptable and having a black tank that you can not drain completely is not a solution.
Good luck. Might be time for the squeaky wheel to get louder. - midnightsadieExplorer IItime for an att. just my .02 cents worth . your dealer did work without approval and now the factory ain,t gonna step in.
- azrvingExplorerIs the tank misaligned so the hole isn't lined with the toilet? Is that a "knock out" piece of plastic stuck in the pipe? Can you remove the tank and see wth is going on?
- RedRocket204ExplorerCould the black tank be slightly moved to where a 45 off the floor flange could plumb properly into the black tank? I tend to think there is probably not enough room to shift the black tank to get the room to do that.
- K-9_HANDLERExplorerOP, sorry to hear ur troubles. Please keep us posted.
DutchmenSport wrote:
K-9 HANDLER wrote:
Uh wow
Dutchmen is that the OP's tank pic?
Yes. I had to work fast to get them before the "Link Removed" happened. But yes, they are both his.
Thanks I never did see that second pic till u got it posted. - IdahoRVingExplorer:C
- DutchmenSportExplorer
K-9 HANDLER wrote:
Uh wow
44,044 PostsLatest Activity: Jul 29, 2025
