the_bear_II
Nov 05, 2018Explorer
Most of the 1990's trailers had the furnace under the refrigerator.
On the inside you should see an access panel to get to the furnace. It usually looks like an air vent.
On the outside of the trailer normally there is a stainless steel oblong plate with two openings. These openings are for the furnace. The furnace will be located on the inside of the wall where this plate is.
