- TheMomoExplorerNo I live in Michigan
- TheMomoExplorerAt this point we literally have no choice but to live in our camper so I'm trying to figure out the best solution on how to use it properly
- midnightsadieExplorer IIare you in a area where it doesn,t freeze? most rv,s area not set up for winter use.
- LwiddisExplorer IIThree months in the winter. Interesting. What steps are you planning for water freezing? Does your furnace heat the tanks? Is the underbelly enclosed? How are you protecting the fresh water hose?
Monroe, WA can get chilly in the winter. - TheMomoExplorerThank you so much for letting me know where it's probably at. firstly I was just trying to familiarize myself with the camper, but mostly because we're getting ready to use it for 3 months this winter.
- LwiddisExplorer IILots of reading needs to be on the schedule of OP.
- trail-explorerExplorer
Beentherefixedthat wrote:
So if you need help just call...
Call who? - BeentherefixedtExplorerThe more insightful question so far unasked is: Why were you looking for your furnace in the first place? Was there a problem? Did it not work? or were you just familiarizing yourself with the trailer...
It's really nice when OP's come back and let us know what happened.
I just removed my furnace, yes it was under the refrigerator, and cleaned it and blew the dust out of it and re-mounted it with a much better mounting so the air actually went down the ductwork.
So if you need help just call... the bear II wrote:
On the outside of the trailer normally there is a stainless steel oblong plate with two openings. These openings are for the furnace. The furnace will be located on the inside of the wall where this plate is.
Look for this on the outside of your trailer...that's where the furnace will be.
