fla-gypsy
Oct 25, 2016Explorer
You have much to learn. As suggested you need to know how much you can really tow first and then realize that nearly all RV trailers share many common parts regardless of price. The major differences in trailers are found in construction technique and some materials each of which has advantages and disadvantages. Often overlooked is the actual chassis components which can have an impact on longevity. Do not get mesmerized on the fluff on the inside and gadgetry that rarely works well. Make no mistake, every maker builds these things as cheaply as possible to maximize return regardless of brand but if you research enough you can make an informed purchase. BTW, I bought a bottom of the barrel TT 11+ years ago that I'm still using very successfully.
44,071 PostsLatest Activity: Aug 30, 2026
