CavemanCharlie's avatar
CavemanCharlie
Explorer III
May 25, 2021
Break Away Cable
I need a new cable for my Break Away Switch. The switch has ESCO printed on the top of it. I can't seem to find a match for that. I'm guessing it interchanges with one of the other brand names. Which brand name does it interchange with ??
Thank-You
(P.S. when I say cable by that I mean I am looking to replace both the cable and the plastic key thing that it is permanently attached to.)
  • you will be better off to:
    1 Remove mounting bolt from old
    2 bolt new one in place
    3 lay out wires along old ones
    4 cut the wires off of the old switch, one at a time.
    5 splice the new switch in.
    The Keys are usually not interchangeable ....just buy a new Break Away Switch with Coiled cable
    Simple......
    When I go to replace the old switch will the brakes be applied when I un-wire the old one ? Should I unhook the battery first ?
  • rlw999 wrote:
    Those unknown Chinese brands on Amazon always make me nervous.
    Ditto. The one linked above is a knock-off of the one Fastway has been doing for about 8 years or more.
    I use the Fastway brand and love them.
    You can get the tether and a new unit or just the tether.
    https://www.amazon.com/s?k=fastway+breakaway+cable&i=automotive&crid=2WZPG9EDBVHHK&sprefix=fastway%2Cautomotive%2C463&ref=nb_sb_ss_ts-doa-p_5_7
  • ScottG wrote:
    I have one of these.
    I like that it can't sag or dangle and touch the ground. It will work with any breakaway switch.
    Those unknown Chinese brands on Amazon always make me nervous. I bought a cheap dog lead once with similar style -- a cable with crimped ends just like that product.
    Pulled into the campsite, put the dog on the lead to let him sit outside, then I walked up to the campground office to check in. When I came back out, the dog was sitting there waiting for me with the 15 foot lead behind him -- one of the crimps wasn't tight and it slipped off.
    So now, for anything safety related, I always look for a brand name that I recognize.
  • (P.S. when I say cable by that I mean I am looking to replace both the cable and the plastic key thing that it is permanently attached to.)
    Simple......
  • I have one of these.
  • Complete unit would be best way to go as the internal parts rust away in most.
