dodge guy wrote:
That's good to know GD. But seems to be complicating the system! No reason to have an LED when you can see if the plunger is out.
Ahh, yes, on the surface one would think that the LED serves no real needed purpose because conventional wisdom would make the assumption that the breaks should work when you have the plunger in your hand..
Sadly though, may not ALWAYS be the case.
These switches live 24/7/365 fully outdoors, rain snow, sunshine, high temps and freezing temps..
They sometimes fail, moisture seeps in from the outside and can corrode and damage the contacts rendering the good looking switch on the outside completely DOA when you need it the most.
I have had to replace one myself when I didn't bother to test the breakaway switch before hauling the RV for the annual state safety inspection.. Failed inspection means I pay for that inspection but do not get sticker until I FIX the problem and have to haul it back to that station to have the repair checked.. Making a 30 mile round trip now 60 miles.
I have often contemplated adding a LED somewhere on the trailer tongue so I can quickly test the switch without the need to hook up a vehicle and pulling or having to grab a jack, jack up a side to test the system..
I actually didn't realize a manufacturer made one with a diagnostic LED.. Might have to consider buying one of these the next time I need to replace one..
I actually keep a spare switch while traveling..
