Kelpike's avatar
Kelpike
Breakaway Switch Confusion.
I recently purchased a 2003 25' Coachman travel trailer. The breakaway switch was crushed on the trailer so I replaced it but I am confused about the power for it. The old one only had 2 black wires coming out of it and going to a white and blue wire on the trailer. Those 2 go into the junction box in the trailer. The new one has 3 wires, blue, white, and black. First, what do I connect the black wire to? And second, it says make sure I disconnect the trailer plug before testing the breakaway. Does that mean it will draw power from my trailer battery?
  • X2, Old Biscuit. After repair, test it! My life may depend on it working.
  • NO....
    It means if still connected to truck and breakway switch is closed it COULD (COULD) backfeed and cause issue with the Truck Brake Controller
    As for the wiring----
    the white is a ground wire, blue wire which will splice into the brake wire coming out of your trailer connector and a black wire which will connect to the breakaway box.
