Nv_Guy
Mar 21, 2021Explorer III
1. Replace the water valve on the toilet - I watched some YouTube videos on this and it seems it should only take 15-20 minutes. Most places seem to want to charge for an hour of labor and $50-$70 for the valve. I'm pretty sure I could do it myself, but it will take longer for me to get the part, and I'm in a hurry to get this stuff done and resume my trip.
As been said most shop have a 1 hour minimum. Also, what is shown on You Tube is not always based on reality. Yes, dealers mark up parts, as does every other retailer.
2. Identify shower leak and repair. When I pressurized the water system I got quite a bit of water spraying between the tub and the shower surround. Because the water leak is that high up (and I didn't see any evidence of water below the tub where the drain line is), I would think the issue is the tub faucet. I removed the tub faucet and didn't see any evident cracks in the fixture, and the supply lines looked ok from what I could see. Anything else I can do to troubleshoot to save time at the repair shop?
If you can, remove the valve and cap the lines then pressurize the system. in addition to eliminating the valve as the source, you can look down thru the holes where the valve was to see if you can see the location of the leak- if it’s still there.
3. Remove portion (8' x 3') of underbelly on rear of trailer, replace insulation soiled by rodents, remove any remnants of rodent activity, and replace underbelly material (it's not coroplast but the thinner, more flexible plastic/vinyl). Any idea how long this might take? I had an estimate from one dealer of 6 hours to do the whole length (17' box; 24' tongue to bumper). So for only about 3 feet of length (and 8' width), any guess on how long this should take?
How do you know the rodents were in only that area? This may turn into one of those ‘chasing the problem” repairs & you may end up having all the insulation replaced.
