schlep1967
Mar 22, 2021Nomad
InTheRockies wrote:
1. Replace the water valve on the toilet - I watched some YouTube videos on this and it seems it should only take 15-20 minutes. Most places seem to want to charge for an hour of labor and $50-$70 for the valve. I'm pretty sure I could do it myself, but it will take longer for me to get the part, and I'm in a hurry to get this stuff done and resume my trip.
If your repair shop can get the part in one day, you should be able to buy that part from them in one day. Replace it yourself.
2. Identify shower leak and repair. When I pressurized the water system I got quite a bit of water spraying between the tub and the shower surround. Because the water leak is that high up (and I didn't see any evidence of water below the tub where the drain line is), I would think the issue is the tub faucet. I removed the tub faucet and didn't see any evident cracks in the fixture, and the supply lines looked ok from what I could see. Anything else I can do to troubleshoot to save time at the repair shop?
If you have the faucet loose so you can see what is going on, have someone turn on the pump and watch where the water is coming from. Just make sure you tell the pump controller to be ready to turn it off when you tell them. A small hairline crack from freezing will open up under pressure and spray water.
3. Remove portion (8' x 3') of underbelly on rear of trailer, replace insulation soiled by rodents, remove any remnants of rodent activity, and replace underbelly material (it's not coroplast but the thinner, more flexible plastic/vinyl). Any idea how long this might take? I had an estimate from one dealer of 6 hours to do the whole length (17' box; 24' tongue to bumper). So for only about 3 feet of length (and 8' width), any guess on how long this should take?
If rodents are in the back 3 feet, they are most likely in all of it. The only way to know is to pull it down and look. No sense in only doing it half-way.
Thanks in advance.
