crazyro
Nov 13, 2019Explorer
ItsyRV wrote:
If I understand this correctly, you have key broken off in the lock itself. Usually the solution is for a locksmith to use a special broken key tool that serves as the head of the key. However, if the lock itself is damaged internally so that it just can't turn at all, they may have to drill the lock, saw the lock or something else that can bypass what is physically preventing the lock from turning.
I would not beat myself up too much over not having a spare as with a key broken off in the lock, not sure what a spare would have accomplished anyways. Not sure if one of those electric keypad locks would have made any difference anyways as it sounds like some physical obstruction in the mechanism. Good luck and let us know how it turned out.
Fortunately, the broken key part I was able to get out. Unfortunately, it seems something broke inside the mechanism. It would not turn at all, no matter what we did. So it may have to be drilled out.
