crazyro
Nov 14, 2019Explorer
naturist wrote:
A few years ago it was revealed that a large number of the most commonly used door locks on RVs were defective, in that sometimes the lock would freeze up if the key was removed after locking if the key was not in the vertical position, but in the horizontal position. When this happened, the door could not be opened from either inside or outside, and the only solution was to drill out the lock and replace the entire mechanism. You don't say what year your rig is, but if it is more than 3 or 4 years old, you may have one of those defective locks.
She's 13 years old, so a very good possibility. I had to scramble and quickly set her up, lock her up and fly overseas so there's no telling what I did in that process. When I came back, no go...
