myredracer
Apr 16, 2019Explorer II
Maybe reducing the amount of the spring's flex/movement would help by installing shocks. Use the tire's sidewall max. psi to also reduce vertical movement (but should run the max anyway).
Not sure if it would help much, if it all, but perhaps install better spring bushings like a wet bolt kit? Stock plastic bushings fail pdq and would allow slop in the spring movement.
