Ron3rd
Apr 19, 2019Explorer III
The spring shop can also install bronze bushings allowing you to run "wet bolts" with a zerk fitting to grease the bushings, thus eliminating the junk plastic bushings that go away quickly and fall out when you remove the spring.
44,071 PostsLatest Activity: Aug 16, 2026
