myredracer
Apr 19, 2019Explorer II
Lynnmor wrote:Stock OEM spring rating on our TT model is 3500 lbs. The factory put 5200 lb springs on in place of 3500. Also have shocks and wet bolt kit on it. It bounces a LOT less and handling is better. No issues after 5 years and over 20K miles. No downside that I can see.solismaris wrote:
Would there be a problem installing springs rated for 5000 or even 6000#? The shop is willing to do that if I want.
A much higher spring rate than required will cause a much harder ride. Since you are getting it weighed, you will know the minimum spring rate needed and then go higher using your best judgement in just how stiff is acceptable. Going to nearly double would be way too much.
