valhalla360
Apr 19, 2018Navigator
Standard issues with new RV's.
Go out in the next couple months and make sure to use and exercise everything as much as possible, so you can find the problems early. Then put a list together and plan not to have the unit for a month or two while they get around to fixing it.
You can spend a lot of time and effort carping at them and might get them to send a tech out to fix it but probably less effort just to pull it, go get the new part from them if you feel capable. (you would be in the right to make them come out but is it worth the hassle)
This is why I like used. A lot of these little issues are sorted by the previous owner and if I do have to repair something, I saved more than enough to cover it.
