DM6156
Apr 23, 2018Explorer
Huntindog wrote:
Out of curiosity.... Do you have shear pins, or were they actually a press fit?
Is there an easy way to tell? Would there be what appears to be weld spots on it? The end that broke off, still has the end of the rod inside - it's not sliding out.
As some seems to suggest, I didn't attempt to raise/level the TT with the stabilizers. Keep in mind, it broke when I was back home and lowering the stabilizer - it was a few inches (i'd estimate 2-3" from the ground) when it stopped lowering.
