32vld
6 years agoExplorer
Build Your Own Travel Trailer
Thought is to take a 15' to 20' long landscape trailer as the base to build a custom travel trailer. Anyone ever build their own trailer? Thoughts, ideas, comments, all appreciated.
Gdetrailer wrote:
Your sarcasm has been noted..
Actually, YES, I HAVE "paid attention" to the frames of TTs. In fact I have studied a lot of trailer frame designs because my plan for my second TT WAS to build from scratch frame up..
What YOU did was wrong to start with, NEVER unbolt the "house" until you are ready to "scoop" it off the frame. The "house" by design ACTS as one huge truss and adds considerable amount of strength to the steel frame.
YOU should have cut the bolts at the dump, THEN push or better yet LIFT the house off the frame (pushing off can twist or tweak the now weakened frame).
Those cheap landscape trailers WILL make a horrible base for any "RV" unless you REWORK the frame CONSIDERABLY which WILL require a lot of heavier steel.. New steel prices are insane..
Now IF the OP is considering a heavy duty flatbed trailer with real I beams and has 2" deck boards then that IS a different critter than the cheap landscape trailers..
I also have a 18' heavy duty 10K GVWR flat bed trailer which CAN and is able to haul a full sized pickup truck up to 7500 lbs.. It IS a beast, weighing in at 2,400 lbs EMPTY.
Compare that to a cheap landscape trailer which might weigh in at 700-800 lbs..
Yeah, my 18ft trailer did cost me $3500 vs a cheap landscape trailer at $1000 but I can assure you a 7500 lb truck would simply squash the cheap landscape trailer..
Just trying to steer the OP away from a potential money pit mistake that they WILL regret down the road.
Don't ignore the foundation, going cheap on that will result in reworking and reworking and reworking..
But, hey carry on folks, MR "Scooby" your shot of sarcasm reminds me of why I rarely post on this forum any more..
