Depending on how much concrete pad space you will have along the side of the trailer, if using the trailer for a guest room, consider that the steps will extend out and you will need sufficient landing space at the bottom of the steps so guests don't step down onto the edge of the pad and twist an ankle.
Also, while you said you don't see ever getting anything bigger, if there is a possibility of getting a newer trailer someday, you may want to just put in 50amp service while you are doing it now, since more new trailers seem to be going in that direction with 2 A/C units. Don't imagine it would cost a great deal more to do that now, and you can put in a panel with both 30 and 50 amp outlets.
