twodownzero
Sep 17, 2014Explorer
Camper_Jeff_&_Kelli wrote:
My 4 gauge wire install and more related information.
I left my original plug wires intact and still use the existing wires in parallel to the new 4 gauge wire installation. The highest charge voltage I would get on the factory wires was about 12.6 volts. With the new 4 gauge wire, I get up to 14.2 volts on high idle and 13.9 volts most of the time at the TC batteries. I wired the new 4 gauge wire directly to the alternator as it eliminates about 9 feet of wire if the positive is wired direct to the truck battery. Length of wire is the enemy. Look at my install above. Should give you some good ideas. The 4 gauge continuous duty solenoid is powered by the activate wire for the factory cube relay to charge the TC batteries. The wires are both in use and in parallel. More wire = thicker wire and better conductance.
I noticed that you installed a separate plug. I'm not ready to reach that point but I am ready to update the truck's wiring and if the charge rate is insufficient, that's an idea for the future.
Anyone have an idea for a weatherproof distribution block? It's going to be under the truck and all the stuff I see online is for car audio. I could wrap the whole thing in tape but I'd rather see something that was more protected from the elements.
