bb_94401
Sep 17, 2014Explorer
It will take time to install your solenoid / isolator (0.6 VDC voltage drop) /relay, fuses and then run the wire in split loom for protection. If you have a single battery, without much Ah capacity 10 AWG or 8 AWG that some recommend makes sense. But for bigger battery banks, 8- 10 AWG is inadequate.
Why is there always time to redo and fix the problem with larger wire and dedicated connectors a second time, than do it right the first time?
While it is possible to run some of your 12 VDC devices in the TC as you travel, the real issue is that the length of wire to the batteries from the alternator and back will cause a voltage drop as you try to push current through it. Measure your runs and do the math with your desired charging current to determine the size of wire you need and the amount of voltage drop you will tolerate.
Vo = Vi - ((d/10) * I * R)
Vi= Voltage in at power source (alternator)
d = length of wire (source to battery and back)
I = current in A
R = resistance in Ohms per 10 feet of wire
Vo = voltage out at TC batteries
10 AWG R = 0.0103632
8 AWG R = 0.0067056
6 AWG R = 0.004572
4 AWG R = 0.0024384
2 AWG R = 0.001524
Vi = 14.5 at your alternator; d = 40 feet (20' out and 20' back); 8 AWG R = 0.0067056; I = 30A
Vo = 13.7 VDC (the typical float voltage @ 50F) little to no charging occurring
To achieve a 1% voltage drop and get Vo = 14.4 to get near a typical adsorption phase charging voltage, limits the current to 5A in 8 AWG wire.
Little wonder that very little charging goes on with 10 AWG wire, given the length of run when you combine the truck and TC wiring.
Supplies:
An online place for insulators, power posts, large fuses/holders and terminal can be found at VTE Warehouse
Most battery only stores, are a good source for terminal lugs, Anderson power pole connectors and flexible wire cable (made by stranding 30 AWG or 34 AWG wire, not the cheap Type II SAE battery cables that use 22 AWG for stranding the cables). They also will swage the lugs onto the cable and shrink wrap it.
Marine supply companies also are a good source for bank select switches, disconnect switches, fuses and other 12 VDC system components (3 stage charging external regulators for 2nd alternator systems.
Solar power companies are also a good source for components.
I = current in A
8 AWG R = 0.0067056
6 AWG R = 0.004572
4 AWG R = 0.0024384
2 AWG R = 0.001524
Supplies:
