Gdetrailer
May 12, 2020Explorer III
Uglyduckling88 wrote:K Charles wrote:
What part do you think is not legal? Over loading the trailer, wrong lights, too wide, too long?
Modifying
Modifying?
Inside?
Outside?
Both?
In reality, at least in the USA there is no "legal" issues with "modifying" the inside, electrically, plumbing, heating, AC or physically. Just be aware, electrically and plumbing wise you SHOULD follow NEC(electric codes) and any good plumbing rules, no US campground inspects those systems and chances of ever getting rejected are near zero.
Modifying the outside in most US States should be "legally" fine provided you follow all State and Federal rules for lighting requirements (running/turn/brake lights and placement of said items), brakes, your modifications do not pose a road hazard , exceed maximum width, length or heights..
But your BEST source of information IS YOUR LOCAL DMV, they should be able to get you all information you will need to legally register a trailer for on the road use. Good chance that YOUR STATE DMV already has a lot of resources online. You can also do a search for "Homemade trailers", your State DMV most likely has some procedures that they require you to follow in order to be able to register a homemade trailer.
As far as modding an existing trailer, you should be able to register it as is with the original title, they should not care if you have changed or altered the interior and the exterior provided you have all of the road safety items in their proper place.
Building a trailer from scratch in many states can be a huge hassle to get titled, better do your research up front before committing to making one, it will be a huge expensive paperweight if you cannot get a title and tags for on the road use.
If you insist on building from scratch, I would highly recommend buying a rotted out trailer that has a good title, remove the rotted box and salvage the windows, doors, appliances, tub and any other super expensive and hard to ship items, it will save you time and money.
Alternatively is if you can get a good deal on just the frame and title, you can do the same but now you will have to source super expensive windows, doors, appliances and so on.
But, really, if this is your first RV trailer, do yourself a favor, buy a older used one, fix what is needed to be fixed (rotted wood can be removed and replaced) and go camping, should have no problem finding bunches of low cost used RV trailers IF you are not picky. This is where you learn how RVs are built and avoid a lot of potential pitfalls of wasting money building your first one..
Something else to consider, a customized to you "one off" build WILL be far more expensive, weigh more than you think it will and in the end IF you need to sell, most likely will not sell or sell for scrap prices.. Folks are used to "name brands", they have an expectation of those brands, a "one off" homemade RV is going to have a very narrow appeal and market..
There are some campgrounds catering to high dollar RVs that may have rules which reject Homemade or cargo trailer conversions so just be aware that if it doesn't look something like a RV with RV siding (like using home vinyl siding or home wood siding) some of these campgrounds may reject your RV.
44,070 PostsLatest Activity: Aug 06, 2026
