Daubers
Jan 06, 2017Explorer
westend wrote:
If you plan for anything less than the 8' span with a foot overhang, making the roof 9', you can use typical SPF 2 x 6, 16" on center. If you want greater than 8', you'll need to go to a larger rafter.
Around here, inspectors are almost entirely married to engineered lumber for load bearing floors and roofs but do allow conventional species of lumber for outdoor projects. We don't have to assume any inspection will be taking place but I thought I'd add that, if so.
If it was me needing a cover over a deck on a seasonal spot, I'd use cedar 2 X 6 for the rafters of a shed type roof, use a corrugated roof panel for the cover, and kick back with a cold one. If the deck didn't need protection from rain or snow, a gazebo type of roof with/without vegetation offering shade, is very inexpensive and easy to build.
Thanks Westend! Those were my initial thoughts as well. Just enough of an overhang to keep the rain out. The main weight will be snow but assumed that corrugated roof panel would do just fine. I went fancy and overkill with the deck itself but no need to do so with the roof. I just want to get it up quick and add some nice lighting and maybe a couple ceiling fans and crack those beers!
44,071 PostsLatest Activity: Aug 30, 2026
