westend
Jan 06, 2017Explorer
Daubers wrote:You can check the ratings of the different types of panels, PVC, fiberglass, polycarbonate, or steel. Any of them will work but I'd steer clear of the PVC cheapos. It's your call and pick depending on the look you want.westend wrote:
If you plan for anything less than the 8' span with a foot overhang, making the roof 9', you can use typical SPF 2 x 6, 16" on center. If you want greater than 8', you'll need to go to a larger rafter.
Around here, inspectors are almost entirely married to engineered lumber for load bearing floors and roofs but do allow conventional species of lumber for outdoor projects. We don't have to assume any inspection will be taking place but I thought I'd add that, if so.
If it was me needing a cover over a deck on a seasonal spot, I'd use cedar 2 X 6 for the rafters of a shed type roof, use a corrugated roof panel for the cover, and kick back with a cold one. If the deck didn't need protection from rain or snow, a gazebo type of roof with/without vegetation offering shade, is very inexpensive and easy to build.
Thanks Westend! Those were my initial thoughts as well. Just enough of an overhang to keep the rain out. The main weight will be snow but assumed that corrugated roof panel would do just fine. I went fancy and overkill with the deck itself but no need to do so with the roof. I just want to get it up quick and add some nice lighting and maybe a couple ceiling fans and crack those beers!
FWIW, the old house I moved into 30 yrs ago has green corrugated fiberglass panels on 2 x 6, 16 OC, at a 14' span, 4/12 pitch, down to the detached garage, across a breezeway. I'd guess they were installed at least 10 yrs before I bought the place, maybe 20 yrs. That's 40, maybe 50 years of service. They are on the North side of the house so see little sun, YMMV. Average snowfall in my area is 48".
Since the panels are green, it can be a disconcerting color in the daylight. I find them somewhat charming but I'm old-school appreciative.
44,071 PostsLatest Activity: Aug 30, 2026
