72cougarxr7 wrote:
Thinking of building my own travel trailer. I bought an old TT frame I was going to convert into a car trailer. I've been thinking more and more that I should just by a car hauler and build a TT on this frame.
The frame has a 18' deck, which is what I want size wise.
I know a few on here have done it, how did it work out?
What did you use for siding and roofing?
My little Prowler has aluminum, and I'm ok with that if I can buy it reasonable and figure out how to work with it.
What is a good place to shop for holding tanks and appliances and windows and doors?
Anyone have floor plan ideas? looking at a queen bed for the wife and I and single bunks for my 2 kids. Not sure if an 18' deck has room for that.
I'm pretty good at carpentry, plumbing and wiring.
If anyone that has built one has any advise or pics, I would appreciate it!
For hauling cars, buy a purpose build car hauler trailer, they are far better built than a RV trailer frame. To use a RV trailer frame as a car hauler you would end up spending a lot of money on steel and welding rods in order to beef it up enough for cars/vehicles.
8-9 yrs ago I bought a 18ft 10K flatbed trailer for about $4K, it is wide and heavy enough to haul a 1 ton pickup truck!
As far as building a RV off that frame you have, that is a good start to that type of project. Someone else had all the labor in removing and disposing of the box.
You can take a look at my rebuild
HERE for some ideas.
I used FRP panels which is fiberglass reinforced panels which you can get at Lowes or Home Depot. Downside is they are only in 4x8 sheets and at that time was $28 per sheet.
Made for a lot of fiberglassing the seams on my part.
I used it for the roof also but it has been problematic of the last couple of years with wanting to split and crack causing some roof leaks. Rubber roof it or one piece aluminum the roof.
I used a rather new aluminumized rubber membrane material called PEEL AND SEAL this year, it only comes in 3ft wide rolls so you do have to overlap it and will have overlap seams.
You can find it
HEREVERY STICKY and if it touches it's self it is game over..
If that fails to work, I WILL be ordering a one piece sheet of aluminum.. Truck shipping on the aluminum and not many places sell it.
One of the largest RV salvage parts places you will find is
RV PARTS NATION in Elkart IN.. From what I understand is they buy leftover parts from the RV manufacturers and have multiple warehouses..
For siding, I would suggest aluminum, I think over all it will be less work and less hassle.. But you will have to have it truck shipped, just too long for any other method of shipping.
As far as buying windows, door, tanks and such, they can be had new but shipping is going to add up.
ALL-RITE MANUFACTURING makes custom windows, doors, baggage doors and trim but it IS expensive.
You might wish to check around for another used junker travel trailer ans a donor for these items.. Just one window at All-rite can easily set you back $400!
Somewhere on this website, there was a fellow by the name of Chad who built a fiver from scratch.. Perhaps someone else knows his screen name and can find it for you..
I wish you luck and if you decide to build, take photos and share.. We LOVE to see folks projects!
