Groover wrote:
valhalla360 wrote:
Groover wrote:
$1,900 is a whole lot less than an inverter drive standalone generator of that capacity, if you can even find one. The closest Honda makes 2,000 less watts and costs $3k more.
Thanks for the info but I'm not sure where you are getting pricing.
A 2400w honda isn't $4900 (7500w is way overkill for a 30amp RV so not really relevant). Heck helped friends pick out a 3100w Champion last year for $550. That will handle pretty much anything a 1/2ton truck can pull. So far the only real advantage is you save some bed space.
If all you want is 2,000 watts, which is all that the Honda put out continuously, you can get that option on almost all of the 2021 F150's for $995. And that is less than the comparable Honda also. Plus, no fuel to mess with, it is always there and it is a lot harder to walk away with.
The only thing I would add it the Honda cannot put out 2000 watts continuously. I have tried, it cannot it will overload.
