Reisender wrote:
One of the you tubers tested an F150 hybrid with charging an older BMWi3 Electric vehicle for a couple hours. Another used a Tesla. Both with well documented results. Looked impressive to me.
Essentially the Tesla Cybertruck will have the same facility. Specs have been varied but 3.6 KW to 7.2KW. Both 120 and 240 depending what you read. The only difference being the Tesla getting its power from the big a$$ battery under the truck. :). No need to wear out the 3.5 litre motor. I’m sure they will have this on the electric F150 next year.
I’ll see if I can find the link on the ford later. It was a good video.
Anyone else see the irony in this post? Plug in your Tesla so it can charge up and then discharge running appliances or charging the neighbors EV that need to be plugged in...
