BurbMan's avatar
BurbMan
Explorer II
Jan 06, 2021
Built-in Genset on 2021 F-150
I saw this in Car & Driver and read more about it at PickupTrucks.com.
You can get an optional 2000W generator on any F-150, the new hybrid comes standard with a 2400W genset and offers and optional 7200W unit with 220v outlet!
This is a huge boondocking convenience for folks that use a 150 to tow a lighter TT or pop-up!!
  • The F150 inverter provides options that could make a big difference in a pinch.
    If CG power fails you now have a power option. If genset fails you now have a power option. Need electric while boondocking you now have a handy power option. Need to use a power tool along the roadside you now have a power option.
    Want to stop for lunch at a rest area, you now have A/C and or microwave available.
    I don't imagine running engine all night, but even then it's an option in a one time crisis.
    I like the idea of a big inverter, If GM offered the option once upon a time I'm surprised it never caught on.
    We can all imagine the inverters being very useful in the construction industry.
    However will the hybrid engine be limiting when it comes to towing an RV?
    Never checked the specs on a hybrid, I know the Eco boost is quite capable, but how capable are hybrids when it come to RV towing?
  • GM offered this with their hybrid Silverado back about 15 years ago. It never really caught on then. I'm in the construction industry where everybody has a truck and I only knew 1 guy that had one. I don't know how long it's been since I saw one on the road.
    Maybe Ford is just marketing it better.
    These are not "generators" in the sense that they have their own engine. They are inverters that convert DC power to AC power.
    Note the bigger ones are only available on the hybrid model. If you are hauling a 5er with 2 ACs, if you add two soft starters, I'll bet it would run both units (7200W at 240V is 30A on each 120V leg.)
    Even with the hybrid, it's still very limited. The hybrid only has a 1.5kwh battery bank. A single aircon might draw 1.2kw, so if you use nothing else, you only have a little over 1hr before the engine will kick on. So that means if you want to run the air all night, the truck motor is going to be running all night. The non-hybrid kicks on the motor pretty much immediately.
    I'd much rather wear out a $600 inverter generator than a $40k truck.
    It could have some uses for light duty stuff but the impression they leave that it's a good option if you want to weekend with the air/con running 24/7 is misguided.
    Now if you want to charge the trailer batteries while driving, that could be a nice use case. Connect the trailer shore power to this unit (have to secure the power cables appropriately) and you could charge at 40-60amps via the standard converter in the trailer. Since the motor is already running, there's no significant wear added to the truck.
    Now if it had a 10kwh battery bank, running the air/con overnight becomes a realistic possibility assuming say a 50% duty rating but that's not what they built.
    I could see this as useful for tradesmen. Running a power saw takes a good bit of wattage but the saws don't run for very long durations.
  • Wizard, correct there isn’t second engine but burb’s report is accurate...an inverter powered by the truck engine.
    At 7,200 watts- I doubt you would need softstarts. I could be wrong and comparing apples to oranges but my 5500 Onan runs 2 A/Cs just fine without any soft starts.
