We have a 2010 Jayco TT. There are little bumps on the linoleum floor. One is starting to come through. Any thoughts of what is causing this Thanks in advance. Travel Trailer Floor
I had one (screw) come up under the carpet. The screw head eventually snapped off. I pulled down the Coroplast under belly and the screw was used to hold down the plywood floor.
Didn't see the need to "screw" with it,there where plenty more holding the floor down.
