valhalla360
Feb 10, 2019Navigator
Check the GVW of the trailer...I'm betting in real life, you will be up around 10,000lb...assuming 15% tongue weight, that's 1500lb on the hitch. Another 100lb for the hitch plus anything in the truck including passengers.
You might be within weight limits but good chance you aren't. Tow rating is the amount you can pull not the amount you can carry.
Even in limits, a 3/4 or 1 to will pull nicer and the bigger brakes will be more forgiving.
44,060 PostsLatest Activity: Mar 28, 2026
