CaLBaR
Feb 10, 2019Explorer II
MarkRBD2019 wrote:
More Info, the payload capacity of the truck is 1750 LBS and the towing 10460 LBS
You have 400 lbs more payload than I have but again first time not sure I would have wanted to tow that length but can be done.
Check your hitch rating as well to make sure it will be able to handle the tongue weight. Use 10 - 15% of the trailer Gross Weight rating for Weight Distribution to make sure the hitch has a high enough rating.
If you think you will be within all of your ratings then just up to you to decide you comfort level.
44,060 PostsLatest Activity: Mar 28, 2026
