Ride_S40T
Feb 10, 2019Explorer
You're going to hear varying degrees of good advice on RV forums and A LOT of solid recommendations based on years of experience.
After considering any or everything read here, please please go out to one of the reputable sites like Shereline and run all the TV and TT specs. Find a worksheet that uses all the specs all the way down to the wheelbase, do not use a simple "pulling capacity" worksheet produced by TV manufacturers.
"Can" you haul something that big behind a 1500 (any make)? Sure. Will it be unsafe or kill the truck? Possibly. Run the numbers, even those wheelbase specs are important. Let the science behind towing be your first guide. Then decide on a TT within those parameters.
Lastly, please know dry weight & tongue weight issued by TT mfgrs can be a little optimistic on the low side. We used a tongue scale to find out our hitch weight is about 100lbs more than advertised.
44,060 PostsLatest Activity: Mar 28, 2026
