rbpru wrote:
Well five pages, the OP should realize that things are rarely as simple as the adds show.
Yes, your half-ton will haul 9500 lbs. of logs, rocks or other such items but it is not going to haul a 9500 lb. TT if you want to carry your family, camp gear and food.
In the real world, a half-ton peaks out with a 5000 lbs. dry weight TT. Half of the weight of food, towels, pots, pans, chairs, tools and other must haves, end up as tongue weight which combined with family and TV gear, peaks out the max cargo long before the 9500 lb. Tow limit.
Don't take my word for it, go to the nearest truck w stop and get the true CAT scale numbers.
I was flabbergasted by my numbers.
Huh? What are you going on about? When did I write anything about having a "half-ton (that) will haul 9500 lbs?" That sounds like a pick-up truck. I don't own a pick-up truck.
