hjcihak46 wrote:
Now, have I miscalculated any of the above or overlooked anything I ought to have considered?
GrandpaKip wrote:
To give you an idea of dry weight, here’s my experience with my present camper. The factory sticker proclaimed a weight of 3820 pounds leaving the factory. On the way home, I stopped at the cat scales. The camper weighed 4150 pounds without me putting a thing in it.
That Passport has a published weight of 3711 pounds. Unless you have seen the actual sticker, that is probably under the leaving the factory weight. Then, there is the real weight when leaving wherever you buy it.
I have not read of anyone that has not had this experience.
Another example ...
My own trailer has a published dry weight of 3535 lbs ...
... but it's stickered dry weight as it left the factory was 280 lbs heavier ...
... and this is before
anything was added to the trailer. Install a battery, fill the two 20 lb propane tanks, fill the water heater tank, and with a few gallons of water in the fresh water holding tank my so-called 3535 lb trailer weighed ~ 4000 lbs
before I added
anything else. Averaging ~ 4800 lbs loaded & ready to camp it's almost 1300 lbs heavier than it's so called advertised dry weight of 3535 lbs. :E
