hjcihak46 wrote:
Thanks everyone for your quick replies and assurances. I suppose it might help if I provided a few more details.
First, I'm looking for something in the 22-24 foot range, & under 3500 lbs dry weight. My SUV is rated for 5000 lbs. I expect I will be the sole occupant most, if not all, of the time. Other than clothes and food I don't expect to be carrying anything really heavy in the TT. I've been considering this for quite some time and have a pretty good idea of what features I consider "essential."
I consider myself pretty experienced in non-mechanical maintenance and repairs and somewhat limited on the mechanical side when it comes to actual repairs.
Where is the best place to get an idea of any particular TT's current used market value?
NOW you have a problem.
22-24ft and 3,500 lbs dry is going to be a stretch.
I had a 1981 20 ft TT which EMPTY (dry) was 4,100 lbs, hitch weight was 550 lbs. Loaded we were around 5,500 lbs and hitch weight of about 800 lbs. This trailer had a GVWR or 7,000 lbs.
My current 1984 26ft TT is 5,500 lbs empty with a empty hitch weight of 650 lbs. Loaded we are around 6,800 lbs with hitch weight of 875 lbs. This trailer has a GVWR of 7,500 lbs.
First, instead of concentrating on the supposed "tow rating" of 5,000 lbs you NEED to figure out what CARGO WEIGHT you have left of the TOW VEHICLE.
The tongue becomes CARGO of the tow vehicle and you typically will run out of available cargo before ever hitting the "tow rating".
You will also need to figure in the Weight Distribution hitch weight into your cargo as it will be dead weight and will reduce the amount of available cargo for the vehicle.
Newer vehicles (2011 and up should have a yellow cargo weight sticker on your drivers side door or on the drivers side door post.
That sticker will list the max amount available cargo (fuel and driver is already figured in with this sticker).
If no yellow sticker, you need the curb weight of the vehicle and the GVWR of the vehicle.
Subtract curb weight from GVWR and the result is the cargo weight.
Now, you need to subtract full tank of fuel, driver, passenger and anything else you put into the vehicle to get the available cargo weight which is left for the hitch.
Because of your limitations of your tow vehicle, you most likely will have to look for "Lite" trailers and most likely a bit smaller than 22ft..
If vehicle is not not equipped with a electric trailer brake controller, you WILL need to buy one.
