zron73's avatar
zron73
Buying a Winterized Trailer
Hi, looking to buy my first trailer. One I have my eye on is winterized. What are the drawbacks in purchasing a winterized trailer? My first thought is I won’t be able to test the water systems (pumps, pipes, etc.). Is there anything else I’m missing?
Ron
  • #1nobby wrote:
    I bought a "winterized" trailer that had also been vandalized...propane tanks and battery...GONE.
    I couldn't test anything. I did the best inspection possible and got it for $3,500 less than asking.
    No big surprises, really, except the water pump was pooched and the cold water, steel braided water line to the kitchen tap was blown.
    That cost me a complete tap set as that line was made of unobtainium.
    Tap set $250
    Pump $180
    Battery set up $350
    Propane tanks $80
    I think I came out ok.
    Good negotiation on your part but I don't think I could get used to those Canadian prices.
    IIRC, I have less than what you have into plumbing for the whole installation in my 22' trailer and I've been doing it long enough not to cut corners (steel braided supplies, full flow ball valves on every branch, enough brackets, etc).
    If the OP's future purchase is a new trailer, I'd take it winterized and fill up the system early next year. He could even carry water and antifreeze if wanting to do the first trip, now. To me it's a non-issue as I can winterize in less than an hour for $6.
  • I bought a "winterized" trailer that had also been vandalized...propane tanks and battery...GONE.
    Tap set $250
    Pump $180
    Battery set up $350
    Propane tanks $80
  • Iwould either put water in it and then winterize again or just dump a few gallons of antifreeze in it and check everything out.
  • Bobbo's avatar
    Bobbo
    Explorer III
    That is all I can think of. You can always insist they dewinterize the trailer so you can test all the water systems. Be sure they fill the water heater so you can be sure it heats. If they want to make a sale, that is not a time consuming task for them.
  • Pitching...as in setting up? I would not buy a used TT without testing all systems.
