bandtroberts wrote:
Hey all. I'm new to campers and need some help. I'm purchasing a Keystone Laredo bumper pull, my truck is a 2006 2500 Duramax.
1. Do I need sway bars?
2. The campground I will be at mostly only has 30 amp service and the camper is 50. Will 30 amp do any damage by not sending enough juice to a/c, fridge etc.?
3. Do I need a surge protector or some type of voltage monitor?
All I can think of for now. Like I said, brand new to campers so any tips appreciated...Thanks
1. Yes. Trailer sway is dependent on many factors and is an additional means of ensuring safety both of yourself and others on the road around you.
2. Depends on how many appliances you have running at the same time.
3. Good idea - I have both. The Surge Guard protects the entire camper and I'd rather replace it than any of the appliances on board. Has worked well in the past shutting down power when needed on at least 3 occasions in as many years. The Voltage monitor helps you keep an eye on the level of voltage in the RV and warns you when it gets too low for expensive appliances (like the AC) to run safely.
If you are going to spend the thousands of dollars to buy an RV it is a false economy to scrimp when it comes to these articles.
